units
DINESHVISHE
units
dear all, how to change bydefault units in pro-e
Hi, When creating a new file, below the "New" file name, just uncheck the box of use default template. Then, it displays a dialog box, on which u need to create a new file. Regards, Balaji.M
1. Click Tools > Options 2. On the Option field write template_solidpart 3. Click Browse and browse to the templates folder on your Pro/E install dir 4. Choose one of the available templates (for example, mmns_part_solid.prt is in mm) You can specify templates for: - Solid parts with option template_solidpart - Assemblies with option template_designasm - Sheetmetal with option template_sheetmetalpart - etc... You may also create your own template and use it with the above options and all new files you create will be based on those templates. Best regards
Kevin
(To:JoseVidal)
If you already have the part created change the units under Edit> Setup>Units. Select the unit system you want and when you select Set ProE will give a dialog box that allows you to convert or interpret units.
