vertion
syam_singh2002
vertion
hai how can i open wf3.0 file in wf2.o
you can't -> only if you export it as a step or so, but then it is not parametric anymore...
Description of and Instructions for the Use of the Granite-Based Cross-Release Interoperability (GCRI) Functionality Implemented in Pro/ENGINEER Wildfire 3.0: https://www.ptc.com/appserver/cs/view/solution.jsp?n=132326
