what is the benefit of the introduction of taper option in extrude?when there is a full fledged separate draft option.
too many same time of options create a lot of confusion like in ...solidworks...there are three known option to select sketch..either through the main tool bar,or right click or by pressing "S".
this over simplification is not necessary.
In our application we find the extrude taper beneficial as it eliminates an extra step.
The parts we build include draft. It is helpful to extrude drafted features with this taper.
I think it is really a question of the construction method.
I advise to use two separate features because it makes it easier to suppress just the draft if needed in the development process.
But I am aware that other designer go for as few features as possible.
I teach my users not to use it. It feels handy and like a time saver, but it typically makes downstream features more difficult and can make later changes to that feature more difficult.
I wouldn't argue that it shouldn't be included in the software, just that robust modeling would limit its use.
Personally I think it needs one other option -added-... taper in the opposite direction for the second direction.
It is silly that it tapers + on one side and - on the other.
When you do text impressions, I wouldn't use anything else.
Maybe a multi-step taper would be even better!
There are a lot of features that have a common taper to them. Collets for instance... 5 degrees every time. O-ring gland walls... taper dowel pins...
that way the Draft option would become redundant Antonius.
Okay, get rid of the draft feature
Draft with Extrude is very helpful in our application which every part of the parts is drafted. This allows the 1 step creation of single feature extrudes.
On the other hand the draft feature also extremely helpful when the profile of our complex parts have varying locks.
Both are great tools.
Agreed. the work with texts is much easier.
Those are great examples of where this feature is useful. We don't deal with them much (except for text), we're typically doing fairly complex injection molded parts. There keeping the draft separate from the extrude makes for a much more flexible and robust model.
pro/e was a spectacular tool...before Creo came in.
it stood out....
now by just aping what is there in solidworks etc....PTC is no doing any good to the software.
they should add capabilities...which would increase the robustness of the software.
concentrate more on the surfacing capabilities...in the foundation package.
improve symbol creation method in detailing
Well, I'm on an old version of creo, but I'd like the option to do an extrude with draft. If I'm doing a REALLY simple part, or, as Antonious suggested, text, then it's a no-brainer. But if I'm doing a complex part, I might not use it. ALTHOUGH, it might help with parent-child relationships in large complex parts, to keep rounds from failing, etc.
