why creo save file so large than wildfire 4
ptc-5343320
A 500k stp file,opened by wildfire 4 then save as prt format is about 700k,but used creo 1.0,the file is about 60m?
Yep, we discussed this a few times.
NOTIFICATION - File Size Awareness
save_model_display wireframe in config.pro solved the issue.
Welcome to the forum, Bird Su.
