The individual system color for hatches does not exist yet and should be introduced, see and vote for this precondition feature request here:
Hatch color for sketches, cosmetic sketches, and cross sections.
Currently (shown in Creo Elements/Pro 5.0, should be the same in Creo 2.0) all hatches are controlled by the "Letter" system color, which drives as well the color of other lines like dimensions and other auxillary lines:
Make it possible that the hatch system color that has been set in the session overules the individually set hatch color.
This dialog allows to set an individually color that should be possible to be overruled by the system color:
All hatches have the same color in a drawing which can be a special color which is not used anywhere else on that drawing.
