2D import data scale in sketches
Would it be possible to add a configuration setting to define the default scale for 2D data when being imported into a sketch?
A 'YES' value would make the default import scale 1:1.
A 'NO' value would allow sketcher to auto-scale the import data (as per current setup).
I would imagine that in most cases the 1:1 scale would be used because the data that you are importing would typically come from another 2D CAD package, where the data has already been scaled to 1:1.
3 Comments
PTCModerator
Emeritus
Status changed to: Archived
JamesAvis
Why is this archived?  I was just going to vote for it because it was never addressed in Creo.
lhofmeister
3-Visitor
Same Comment as the user above:
