The new 3D Box Select tool doesn't provide the user the same options as the CTRL+. Once items are selected it should be irrelevant which method was used to select them and have the same options available with either method.
Options which should be added:
Delete
Group
Suppress
Move to New Subassembly
Replace
Backup references
Hide
