I need the ability to make 3D cross sections with any sort of sketch or curve whether it is a straight line or not.
Currently you can only make an offset cross section with straight lines. I need to make them with arcs or splines.
Currently you can only make zone cross sections with straight/flat surfaces. I need to make them with non-flat/straight surfaces.
I can't believe I have to submit a request. Its a cut!
