3D Dimension line and withness line thickness
As we are able to change dimension lines and witness line in 2D drawings in PDF or DWG file when we export them. Their should be an option doing the same for the 3D items when export them or while they are being rendered into an image file.I have attached an example were you can see the dimension seems to be distorted and very light
1 Comment
olivierlp
Community Manager
Status changed to: Archived
