48911 - Would like Tapped Holes (Machine Feature) to be able to default to a Zero Chamfer)
A majority of my tapped holes do not require a chamfer.  The tapped hole values in modeling are defined in the "mach_adv_library-tappedholes-thread_dia-table" - if i set the chamfer rad to be the same as the Tap Rad, it seems that the Chamfer details in the Menu (default of 120 degrees) default over the settings in the Table.
My Enhancement\Product Idea is that i would like to be able to set a zero chamfer default for Tapped holes created from Machine Module Feature.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
