It would be useful if there was a button, like there currently is in the flat state preview, to allow automatic flat state creation by means of a simplified representation.
A lot of times people encounter problems with using family tables when it comes to saving copies of data or when working with Windchill, and therefore resort to the Simplified Rep method.
Currently a mapkey is written and icon created in the UI to make this process as seembless as possible, but some users do not have the knowledge to do this and it would be convenient if there was such a button. Perhaps even have a config.pro setting allowing you to determine the type of method applicable to the flat state preview flat state button. In other words, having the ability to set the flat state preview flat state button to use either family tables or simplified reps to create flat state
