It would be a real time saver if there was a button or a way to open the corresponding drawing for an onscreen model or assembly ? The other way around is easy as in the drawing you have on the left bottom a component tree to open the component but not reversed. This operation, retype the number of the drawing, is done several times a day by many designers and would be a real time saver. They are dreaming for years to have this
