Apparently, there are major issues with the new Creo 4.0 ASME Symbol font. If you export it as a dxf, dwg or pdf with the setting to NOT be stroked, it does not export well. In dxf and dwg, if you double click the text, the symbols convert to boxes. In PDF, they just show as boxes. Please fix ASAP!
-PTC management can refer to case 13941435
