It is not easy to create the cams in the right order, so be able to reorganize them would be considerable help.
In addition, to be able to copy and paste cams would save time. (Paste Special > Advanced reference configuration)
Additionally, to have the option to repeat cams (for gears) by reference would be appreciated.
