Ability to accept alternate reference
Creo will find automatically pick an alternate reference for many features when you make a change that modifies or replaces a feature in the model, such as adding a draft or combining similar features.  The reference is then marked with a yellow dot to indicate this.  I would like to be able to "accept" this substitution to remove the indicator that something may not be correct.  Currently the only thing I can do to remove the substitution is delete it and reselect.
2 Comments
dgschaefer
Absolutely!
olivierlp
Community Manager
Status changed to: Archived
