Ability to automaticly fill in the depth value when picking a surface for blind extrudes
0 Kudos
For in the context of the assembly design wirkflows: In creo when you want to extrude up to a surface of another part there should be the possibility to do this via the blind option, picking the up to surface of the other part and that creo then fills in the rigth value for the blind depth. In this case unwanted external references can be avoided.
Nowadays we have to measure this value and enter it for the blind depth.
Implement above workflow for all items where values have to be entered for example also for offset datum planes
