Ability to change explode order
The User now can't redefine an Explode State and change the sequence defined because it is not tracked anywhere. It would be interesting in order to generate and manage movies that come from an explode sequence. If you make mistakes, now it's impossible to fix it; you must delete the Explode State and do it again.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
