I need to have a steady center curve for building sweeps. To get this it is necessary to have center points of all the sketches that are chained together to build the sweep.
Presently you have to use the Behavior Modeling extension for the center point ability, and it is very tedious.
1) Extrude the sketch
2) Use the Analysis function
3) Save center of gravity point as feature
4) Capture this point in the extruded sketch
5) Repeat this for every center point needed
When you have upwards of 20 sketches included in the center curve for a sweep this is very time intensive.
