We often have a need to dimension a drawing with both US/Imperial and Metric dimensions. We don't want "dual" dimensions but rather the ability to display a particular dimension in a different unit than the rest of the drawing. As stated in a similar request, it is relatively common to need a metric sized or threaded hole or other features in a normally English dimensioned drawing.
