I would like to have similar functionality for Creo Parametric Save As function as you have with Windchill.
When doing a Save As from Creo Parametric and afterwards check in to Windchill, you get an error as the name of the flat instance already exist in Windchill from the original file.
Doing a Save a Copy in Windchill gives you the ability to save the instance with a new name.
Right now you can only save the generic Part file and the Drawing under a new name. Not the instance.
