Right now, the dimension and crossection arrow length and widths are controlled with the detail options draw_arrow_width, draw_arrow_length, crossec_arrow_length, crossec_arrow_width. But this forces these sizes to all be exactly the same on each and every sheet or even drawing view. We often make multi-sheet drawings with different models detailed on different sheets. These could be family table parts or even independent parts. But the sizes of these parts may vary quite a bit such that we need to use different size sheets and thus different size dimension text and arrow sizes. It is possible to independently vary the dimension text sizes but the arrow sizes are controlled globally from the detail options as per above. I would like to be able to control these sizes on a per view basis. Even on a per sheet basis would give me more than what we have today.
