Ability to reset all view manager states
There should be a standard way to reset all View Manager states. These should be built into Creo and non-editable.
They should all be consistent in their offering.
For example:
  • Simp rep has "Master Rep" which will clear all simplified reps.
  • Orientation has "Standard Orientation" and a modifyable "Default orientation"
  • Sections have "No Cross Section"
  • Style has "Master Style"
The following need resetable states as well:
  • Combined states (has default all, but not master all - rep callouts are still displayed on the window and layer state remains because there is no default or master layer state)
  • Layer State
  • Exploded view (has the checkmark to reset, but should have a "no eploded view" as well for consistency)
The default or master layer state should refer to the "save status" layer state. If you are in a layer state "save status" will save to your default and "save..." will save to the layer state. So layer states could get accidentally saved over your default layer state.
3 Comments
TomD.inPDX
Not sure I understand all of this request but do agree that a -reset- option is highly desirable.
I have also noted that some states are not stable.  They work while you are in session but once you save/exit/erase memory/ and bring the part back up, it comes in at a different state.  Many states are cryptic at best.  To much going on behind the scene.
PTCModerator
Emeritus
Status changed to: Archived
PTCModerator
Emeritus
