Ability to search subfolders in Material Directory
Currently when using a Material Directory in Creo (tested in 4.0) if you have multiple sub-folders the search in the window does not search within the sub-folders. With many material files of differing types it's beneficial to use sub-folders.
The search also appears to only search on the filename, which limits the search capability. It would be beneficial to allow searching on filename, name, description, and user defined attributes at a minimum.
