Ability to set default scale for sketcher palette items
Many of our sketcher palette items are standard sizes for o-ring grooves, slots, etc.  These should always be used with the scale of 1.0.  We would like to be able to set a default scale for some items in the palette instead of them coming in with a scale based on zoom in the sketcher window.
4 Comments
BlitzSpirit
Visitor
I agree; it is most annoying that the sketch is inserted with a random scale.
For information the PTC reference is https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS127410
Please vote for this enhancement!
PTCModerator
Topaz I
mneumueller
Pearl
Status changed to: Clarification Needed
Would it be required for that default scale of 1.0 to be configurable for each of the items in the palette?
or would any of the below already help?
a)  global config already help?
b) Or maybe a button in the UI to quickly set the scale to 1.0 instead of having to type in that number?
mmuhamedagic
Regular Member
Hi All,
just a remark. As you probably all noticed, scale factor is set by default accordingly to windows/creo zoom during importation, and there is some kind connection between this. It should be easy for Creo developers to explore this bound and to do extra config option. If you agree of course.
One click Button seems to be tempting, but it is better to have a option. Some time we (my company) need to import more than a hundred times different symbol from palette and no need for extra macro please. And it should be available in part/assembly mode as in drawing mode.
Thank you.
