The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Able To Change Dimensions With Offset Feature Like in Flexible Modeling (Move Geometry)
For example you have a solid model and you give some dimensions on solid model surface at drawing with dimension tool. Then you offset one surface so your used edge disappear correctly but dimension does not change or give an warning. But if you move this surface with flexible modeling, dimension is changed. Customers think dimensions must be changed with offset feature too.
Video link = https://www.opendrive.com/files?OF8yMzQ3OTY5MF9IeVFlaQ
2 Comments
Dale_Rosema
23-Emerald II
Vahap,
You may want to vote on your own idea....
PTCModerator
Emeritus
Status changed to: Archived
