The chamfer dimensions of the import feature can not be displayed as 3D dimensions when Drawing.
As a method to solve this, there is a method to recognize it as a chamfer by a Feature recognition tool.
However, it has the following conditions.
The length of the slope is equal to or less than the thickness,
the length of the plane adjacent to the slope is 1.2 times or more the length of the slope.
Since there is no way to avoid these conditions, work efficiency is bad.
Therefore, I want you to eliminate the above conditions.
