About printing line
About printing line
When we print the drawing by thick lines,
The intersection of the lines becomes the step.
In Japan, the step is not preferred.
So, I want to eliminate the step.
3 Comments
Peridot
If this is PDF export, the options dialog allows for line-end conditions
(Creo 2.0)
If you don't have enough resolution, however, you might still end up with unfavorable graphics when you zoom in significantly.  Often a problem with drawing views with scales that are to small for normal 1:1 printing.
Contributor
Thank you for your information.
I don't know this option.
It's good option.
But the option is not in Printer Configuration.
I want change line-end conditions in Printer Configuration,
because I use plotter.
Community Manager
Status changed to: Archived
