Random vibration simulation is performed in Creo Simulate and its output response of acceleration vs frequency is unable to extract.
This feature is useful in order to measure the output vibration levels when we are comparing the simulation with the test result. Also this will help in identifying the acceleration levels with respect to frequency at a particular location.
