Activate and De-Activate from pull down menu
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What version of Creo Parametric are you currently running?
7
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Activate and De-Activate part in assembly from pull down menu
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
8 Comments
szycha63
8-Gravel
I wish new idea post would be easier and simpler to do 😞
StephenW
23-Emerald I
One of the reasons they ask for "extra" information is to understand your problem and what you are trying to accomplish. I also helps other forum members understand which will get your idea more votes.
While working in an assembly, I can RMB on a part and activate it. I "deactivate" it by Activating the top level assy.
I added the "activate" to the quick access toolbar for "quick access".
szycha63
8-Gravel
I get that but
why we have to deactivate on top level not in the same place it means if you can activate part from this menu WHY you can not deactivate from this menu? 🤔
StephenW
23-Emerald I
That's valid.
To me that's an extra step from my process (select the part first to get the activate/de-activate menu to pop up) but would be consistent from a workflow perspective.
Activate is always available using the quick access toolbar (provided you have it turned on)
szycha63
8-Gravel
I was not aware of this icon, nice hint
Domen
Or click CTRL+A on keyboard to deactivate part/activate main assembly.
olivierlp
Community Manager
Status changed to: Alternate Solution
szycha63
8-Gravel
Thank You great hints
