PTC,
Please add the ability to change a table row height while entering in text by adding in a right click menu option.
also
Add the ability to change table cells without having to un-selecting the table.
You should be able to either tab cell to cell while entering in text or use a mouse pick to select the next cell to enter text into. You should not have to pick out side of the table in order to enter text in another table cell.
Verified in Creo 3.0 M080
Don Anderson
