Please add the ability to select Simulate Features in a Model or Assembly and allow you to Right Click on them and select Locate In Model Tree.
The Simulate feature trees collapse regularly and its very time consuming to expand the model tree and find simulate features in an complex assembly.
One should be allowed to select a fastener or contract region from the assembly and right click and have the software tell you where in the model tree it exists so you can quickly edit or suppress one or more of them.
Don Anderson
