Add Ability to Select a Component in Creo Parametric Simulate and Show Only All of the Dependent Simulate Features
PTC,
Please Add Ability to Select a Component in Creo Parametric Simulate and Show  All of the Dependent Simulate Features for the component that's selected.
This could be an enhancement to the Reference Viewer and also a Right Click on the component menu with a Info command window to show what simulate features are dependent to the component.
I have a component in a assembly where I want to find all of the Creo Simulate Contact Interfaces that reference this component.
From what I can tell, Reference viewer unable to display the Creo Simulate features that are dependent on a particular component.
Info by model doesn't show the info either nor does info simulate.
Please add this functionality so when one person needs to replace a component in a assembly they can identify what simulate features need to be re-routed to the new component.
Don Anderson
reference:
How to select a component in Creo Parametric Simulate and show only all of the dependent Simulate fe...
2 Comments
danderson
11-Garnet
Quote:
Hi Steven,
Yes, if you do a info on the interface in question or edit the interface it will show you which component the interface (load, constraint, etc ) is tied to.
What I'm looking for is a one stop shop by selecting one component in an assembly and having reference viewer or component info show me all of the contacts, springs, loads, constraints, surface/volume regions, and any other simulate features that are dependent on the Component that I want to replace in the assembly so the references can be re-routed to the new component. This at worst case would allow me to create a list of all of the features that need to be re-routed to the new component.
As far as I can tell there's no way currently to see what's dependent on the component. Even selecting the component and hitting delete will not highlight in the model tree what simulate features will also be deleted or suppressed when the component is removed from the assembly. By the way, one can't delete a component while in simulate mode in Creo Parametric and when your in non simulate mode and you try to delete a component you can't see what simulate features will be deleted when you delete a component. If you do this other components will also be suppressed or deleted so deleting or suppressing in assembly mode is of no value.
Think of replacing one component that has 50 to 100 contact interfaces plus simulate fasteners referencing the component in a large assembly.
Hope this makes sense?
Don Anderson
olivierlp
Community Manager
Status changed to: Archived
