Currently only constraints in the main relations stop regeneration to ask if you want to continue or not. Constraints in other relation locations (Post, Component, Feature) only show a warning message in the message log. These constraints can get overlooked very easily. With the introduction of the Notification Center it makes sense to put the warning there.
