Add DRW config option "Default Tolerance Table"
Salut,
we have Drawing option "default_tolerance_mode" (nominal/plusminus/plusminussym...) but missing option for default_tolerance_table. We need to preset "None/General/Broken Egde" for new dimensions in config.
Nowadays we must manually set every dim like "None" in order to allow modification of dim tol value by mouse doubleclick because in "General" mode it is not working. Solution via mapkeys is clicking orgy...
1 Comment
olivierlp
Community Manager
Status changed to: Archived
