Add Edges to Draft Check Display
When performing a draft check, the model turns two color showing clearly where the break in draft is.  However, all shading and edge information is not displayed, so the contour of the model is very difficult to read.  Adding the edges to the draft check display would solve this.
Here are two images, one of the shaded model with edges and one of the model in draft check.  You can see how adding the edges would improve things.
2 Comments
Participant
Yes, this would be GREAT!!!!
There are times where I have different draft on some features and you cannot navigate the part to understand what is going on with a feature since there is NO detail.
Before WF4, draft check was much better.  Make it more like that was.  What PTC has made it now is a downgrade from what it was.
Community Manager
