Add Excel functionality to Tables in Creo Drawings
Vote to add excel like functionality to ProE drawing tables.  Some important examples are:
  1. Navigate through table boxes using the arrow keys, F2, and Enter
    (This would allow for much faster text entry without needing the mouse, just like in excel)
  2. Copy and paste multiple cells simultaneously from one section of a table to another or across different tables
    (i.e. groups of cells, such as entire rows/columns)
  3. Border thickness control for each individual cell or groups of cells in the same table
    (this is for greater visual clarity of the content of the tables into logical groupings)
  4. Quickly deleting or adding new cells, rows and columns using keyboard shortcuts
    (In Excel shortcuts are CTRL+SHIFT+"+" or CTRL+SHIFT+"-")
  5. Reording and moving Cells/rows/columns
  6. Text to columns input where you can copy text from one program and paste it into Creo (like in excel) and set it to deliminate to the correct columns (Excel feature is called text to columns and can be done even through the pasting interface)
  7. Include all above funcionality in comment areas of tables with Repeat regions
There is much more excel functionality that would be useful (such as conditional formating, logical operators, reference other cells, sorting rows alphabetically, etc) but the above are the areas where I see the biggest efficiency gains.
Voters, Please comment below if I missed other table functionality that would yield big efficiency gains if added to Creo.
Long have tables been slow to work with, clunky, in-flexible, and overall frustrating to work with in ProE, BUT this just means it is an area of great opportunity for improvement!  This is an excellent opportunity to dramatically increase the speed and efficiency of getting work done in Creo.
Please vote if this added table functionality would help you get work done faster in Creo.
9 Comments
Dale_Rosema
22-Sapphire I
Here is another one asking for the same thing. You can vote for each.
http://communities.ptc.com/ideas/1202#comment-5684
rmitchell-2
1-Newbie
http://communities.ptc.com/ideas/1542
Simply, clicking on the link doesn't seem to work.
Copy it to your browser address field.
Please vote for my same idea, maybe PTC will understand.
lscheeler
I am not sure why these did not come up when I searched for this before I posted but  I am glad you are posting links to make sure that other people find these to vote on them
fmueller
3-Visitor
  FRIEDER MUELLER 05.05.2014 23:55
Very good idea,
I would like to add that reordering of rows and columns should be possible via drag & drop
AND:
Dont forget to vote for fixing the insertion of links:
http://communities.ptc.com/ideas/2622
from above
Thanks, Frieder
dcookson
1-Newbie
The table functionality in drawings is ridiculously bad.  It is as if PTC purposely made it difficult to use, adding multiple unnecessary clicks and wasted time.
PTCModerator
Emeritus
irobinson
3-Visitor
@PTCModerator does acknowledged mean you know this request exists or that something is being done about it?
This post is 6 years old and we're all still crying out for this functionality.
We need you to fix things that make our lives easier / better / are driving us towards Solidworks rather than pushing IoT and other stuff we won't use. PLEASE fix this! Thank you.
Mfridman
Status changed to: Under Consideration
These are all great ideas
The table formatting ideas will be considered as potential candidates for our future releases
OliverHeins
The functionality enhancement should be added to all kind of tables. In our case It was necessary to copy and paste multiple fields to a pattern table. Currently it is only possible to copy and paste the content of one cell only.
