Add PMI table support to Creo Parametric
NX has a feature called PMI table, which allows a designer to insert a table into a 3D design with linkage to PMI annotations.  See attached screen print for an example.
Creo's table feature is limited to drawings, but the PMI table is needed on the 3D design, to support model based definition and design.
1 Comment
Mfridman
Status changed to: Under Consideration
