Add Saved Analysis to model tree
Currently, the only way to find a saved analysis that is hidden is to click on the saved analysis button in the Analysis tab.
Also, saved analysis are not searchable in an assembly.  So, if they are left as shown, it is very difficult to find in a complex assembly.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS160085
PTC, please make saved analysis more robust by adding it to the model tree and allowing it as a search criteria in the find tool.
3 Comments
jsarkar
1-Newbie
What is the application of saved analysis? since if you want the analysis as feature you can add as feature.
Steven,
He is talking about the analysis for dimension or curve length etc checking. I guess.
dhermosillo
Specifically, surface curvature analysis
PTCModerator
Emeritus
Status changed to: Archived
