Add Transparent Shading with Black Edges Display Style
The idea is to be able to quickly see through the parts/assemblies for holes, cuts, etc. Without the need to switch to wireframe display style and so without the need to change the display style at all.
4 Comments
KevinBradberry
Jakub,
Can you explain this again?
With transparent shading, do you mean see-through with color?
Aren't you still going to have switch to "Transparent Shading" mode when you want to use it?
James62
9-Granite
Yeap, see through models with shading/render (color). The point is that wireframe isn't very representative and it's actually very laggy with large assemblies.
I am not even gonna mention display with hidden lines there.
Oh well, I just did.
Thanks for pointing that out, Kevin.
James62
9-Granite
PTCModerator
Emeritus
Status changed to: Archived
