Actually, is it not possible to create the CL-Data für tailstock and lunette movement over a feature.
It´s necessary to write a CL-command in a manual cycle.
But with this command there is no visualization during playing the toolpath possible.
The idea is to add a feature for those things.
For the lunette I think the following actions a necessary:
- open
- close
- change position
For the tailstock:
- change position
- change the head
- change position of pinole
There must be a possibility to deactivate the output in the CL-Data
