It would be great if there was a ModelCheck check that would catch the presence of unattached features. It would be great if this check could catch unattached solid features and sketch/surface features.
For example we have a specific problem in MBD models where we create designated areas on a surface, that surface then has draft applied to it and the designated area is no longer "on" the surface. This can be hard to detect visually and having a check for it would be very helpful.
