When adding radiation or heat flux loads on an assembly, there is no feature to allow for the selection of all EXTERNAL surfaces of the assembly. One can only select "boundary" surfaces of each component, which results in the selection of a lot of interface surfaces which would not actually be exposed to radiation. The only other option is to select each external surface individually, which can be very tedious for complex assemblies.
