Add a shutdown method for sychronous batch applications to Object Toolkit
0 Kudos
When implementing Creo Batch applications (Creo option -g:no_graphics) with Object Toolkit (Java and C++), there is no simple way to end the creo process as it is available in Pro/Toolkit with ProEngineerEnd().
Using ProEngineerEnd() through the task based application library does not work.
The only available workaround is using a macro, but this does not end the creo process in all cases (e.g. if a traceback file is written, if some user specific input is expected, ...), Thus, Creo has to be killed in the task manager which is not really an acceptable solution for a productive use of a batch application.
See also PTC Case C12342539.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
