1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Space
MCAD Administrator
Engineers
2. What version of Creo Parametric are you currently running?
Creo Parametric 8.050
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Currently, the Notification Center in Creo shows which objects have messages, warnings, errors, but in order to see the actual notification, you must hover the mouse over the object for about 1 second. For one object this is not too bad, though it is not intuitive. Even clicking on the object does not reveal any information about the message. However, in larger quantities, inspecting each object individually with a mouseover is frustrating, slow, and inefficient.
Add a table view with columns and view customization so the object and the message can both be seen, sorted, grouped, and filtered.
4. What is the use case for your organization?
Viewing notifications
5. What business value would your suggestion represent for your organization?
Increased efficiency, accuracy of notifications, less time wasted.
