Please add the ability for Creo Simulate Screw Fasteners to work with Tapped Hole Lead In Chamfers and Counter Bores. This would prevent the need to remove these chamfers from the model and allow the design to be saved to the PDM system as it was setup for the FEA run. This enhancement would remove in most ways the error message "No contacting surface pair could be automatical AutoGEM"
