In creo 2.0 the color of the active field (dark pink) is too close from the color of a non-active field (pink), So it is not easy to make quickly a diffrence between these 2 fileds. In Creo Element Pro 5, it was easier
CREO 2.0 CREO ELEMENT PRO 5
It would be great to be able to change the default color of an active field
