Add ability to customize the default part, assembly and drawing file name
For current functionality, unable to customize the default part, assembly and drawing file name. We have to modify them by manual when creating new files.It make use crazy as always.
5 Comments
TomD.inPDX
In Creo, you can set the default template file.  Go to the config.pro editor and -find- "template".  You can set the path and filename for each filetype you want as the default template.
ptc-4226637
1-Newbie
I think qimin zhou want to customize the default file name ,for example prt001,  drw001 instead of the default file template. Set the default file template by config.pro option is availabe starting at old version Wildfire 2.0 for many years.
MartinHanak
24-Ruby II
I think qimin zhou has to post his suggestion how to define rules for name specification.
Martin Hanak
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
