Add ability to move partial view spline points
When a partial view spline is needs to be moved a little, you are required to redraw the entire spline.  I would like to see the ability to move the points defining the spline for making adjustment to the outline of the view.
3 Comments
StephenW
23-Emerald II
Every once in a while I have to be precise on my detail view splines to not have extraneous geometry show up in my detail or partial view. This particular view has 7 areas I have to micro manage plus 2 long straight areas I have to stay within.  I just spent a 1/2 hour redrawing a boundary over and over again because I couldn't get all the way around my geometry without messing up some pick point along the way. Having to start over and over on this particular view was painful.
Give us the ability to simply drag the spline points after creation so we can tweak a view border without having to completely recreate the spline.
dmcclinton
11-Garnet
Great Suggestion, I go through this painful process on a regular basis also but hadn't thought of creating an enhancement request.
olivierlp
Community Manager
Status changed to: Archived
