Add ability to place section arrows on broken views.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Mechanical Designer in metering technology.
2. What version of Creo Parametric are you currently running?
Creo 7.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Adding section arrows to a view that has a break in it seems impossible or disallowed. It would be greatly beneficial to utilize broken views to display section arrows of another sectioned view.
Workarounds for this feature have included sketching the arrows over the broken view. Or placing partial views with the arrows over the top of your broken view and then blanking all components in partial view. However none of these solutions are desirable as they will either not regen if the section/scale is changed or, they will not update position placement on broken view.
4. What is the use case for your organization?
To create better and more functional drawings for our product.
5. What business value would your suggestion represent for your organization?
This would minimize the number of views needed to communicate our product design in drawing mode. Thus, making more coherent prints for our internal staff and vendors.
4 Comments
StephenW
23-Emerald I
I hadn't seen this before. I think it only occurs when the section is thru the area "broken away"?
But it is very hit or miss and also has to do with which of the broken views you pick.
I know I've done many sections with broken view arrows and had never noticed a problem but I was able to re-create the issue relatively easily.
I'm on Creo 4 still.
TL_10036246
Sorry, I forgot to clarify offset section views.
@StephenW, regular sections arrows work just fine with broken views but I haven't found a way to place offset section arrows on broken views.
olivierlp
Community Manager
olivierlp
Community Manager
Thank you for your idea and the information you provided.
