Add ability to select CYS to determine lattice vectors
0 Kudos
Currently the lattice functionality within the additive manufacturing module only works off the default coordinate system vectors. The enhancement idea is to allow the user to select a different CYS to determine new lattice vectors.
Currently a work around for this is to assemble the part into an assembly such that the assembly has the default CYS that is desired, step the assembly out and then import it back in as a part. Obviously this breaks parametric ties but may be an ok workaround for temporary 3D prints.
2 Comments
Chris3
Opal
This idea is current functionality in Creo 7
JoseCoronado
Amethyst
Status changed to: Current Functionality
Current lattice functionality can be oriented using an alternate CSYS, for both orientation and first cell position. Please see below:
This idea was implemented since on the first release of the Lattice feature. Please send me an email with your specific model and we can do a screen sharing session when you can. jcoronado@ptc.com
